C5 X7 Negative Battery Cable
ThoreT
Unread post by ThoreT »
Hello
I'm suspecting the sensor on the negative battery pole is acting up, as I get fluctuating voltage readings when the engine is running (I've tried to clean the connector, voltage measuring on the poles when running is consistent 14,4V)
I went to CatCar Info and entered my VIN-number. The search turned up a bewildering number of different battery cable assembly part numbers. Any idea how I can find the correct one, or will they probably all work?
All the best,
Thore
x 8082
Re: C5 X7 Negative Battery Cable
If you post your VIN, which will be masked from general view, someone with access to the parts system may be able to help :)
PaulC5
x 670
Unread post by PaulC5 »
Have you checked if your car has a smart alternator that varies its voltage. If reading low put on the headlights and rear window heater to give it some load and see if the voltage goes up.
