Clio 2, 1.4 16v (2003) - Airbag light on after heater core replacement
Kukkakeppi
x 7
Unread post by Kukkakeppi »
Hi everyone,
I just finished a major job replacing the heater core on my Clio, which as you know, requires tearing down pretty much the entire dashboard and cabin.
Now I’ve ended up with a persistent airbag light, and I’m trying to figure out the best way to start troubleshooting this.
I scanned the car with Renolink, and the fault codes point towards the rear seat belt pretensioners. You can see the codes in the attached image:
• 9016 – Enrouleur pyro arrière côté passager (Rear passenger side pyrotechnic pretensioner)
• 9015 – Enrouleur pyro arrière côté conducteur (Rear driver side pyrotechnic pretensioner)
• Both codes show “Circuit ouvert” (Open circuit).
• The fault is both present and active (DTC présent = 1).
I highly suspect I’ve left a wire unplugged somewhere, but I just can't find the matching connector for it.
On the passenger side near the door/footwell area, there is a loose black and yellow connector (shown in the picture) that I can't find a match for. The wire doesn't reach very far, maybe about 20cm, so roughly to the glovebox area. On the other hand, it looks like it might come from the airbag module inside a larger wiring loom.
Additionally, right by the airbag module, there is an identical yellow and black connector, but I can't find a matching plug for that one either. Is there supposed to be a wire connected to it? I was wondering if a wire should run from there up along the side of the heater core housing, but if so, I have no idea where I could have misplaced it. Or could this be a completely different issue? I strongly assume everything is related to this loose wire...
Any help or insight would be highly appreciated. Thanks!
x 8151
Re: Clio 2, 1.4 16v (2003) - Airbag light on after heater core replacement
I don't know if this may help but have a look and see what you can work out (ignor the link title): :)
https://www.caretxdigital.com/alko-elec ... g-diagram/
See if this helps...
This is a Renault rear Sealtbelt/Pretensioner of 2003 vintage. The dtc's relate to the rear pretensioners so a reasonable approach would be to uncover the rear seatbelt and pretensioners assembly and follow the wiring from there back to the SRS ecu. Clearly the SRS ECU has detected a lack of continuity in the circuit from the SRS ECU to the rear pre-tensioners, so there is some break in the wiring/connectors.
The photos you include also show that the side-curtain air bags passenger and driver are not detected. Is your vehicle fitted with those airbags? Not all models/trims may include the curtain airbags. I suspect your vehicle may not have them and hence possibly responsible for the "unused" connector" on the loom. Despite non-detection they don't appear to throw throw up a fault code which would be logical if the side curtain airbags are not present in your specific vehicle.
Kukkakeppi
x 7
Thank you for your message!
It really could be so that there is no side-curtain airbags and that is why there is that unused connector. I will check that tomorrow.
Also, I think you are propably right, I should try to follow that wiring from pretensioners to Ecu. Maybe I have pulled that wiring somewhere along the process. :) Thank you for your help!
Kukkakeppi wrote: 17 Sep 2026, 20:46 Thank you for your message!
You are very welcome Kukkakeppi and your acknowledgement is appreciated. Courtesy and good manners which I personally hold in high regard so thanks for your message and hope you solve your fault. The light on is simply the ECU doing an initial test of the components of the SRS system, a bit of logical following through should come up with a solution. Your diagnostic test already points you in the direction of the rear seat pre-tensioners so you have a good start!
Kukkakeppi
x 7
Well, I opened the back seat and now my problem is that, there is no pretensioners in the rear of the car, I check both sides and also seat buckles, so... How do I continue from here :)
Any ideas would be welcome :)
I believe that this car never had those.
What does that check show?
Passenger-side rear Pre-Tensioner Detected...1 Resistance 5.15 Ohms (very possibly OK check as far as the SRS ECU is concerned)
Driver-side rear Pre-tensioner Detected....0 Resistance Out of Range (driver-side rear pretensioner non-existent/disconnected/wiring break)
That would seem to suggest that the SRS ECU has detected and measured resistance of the passenger side rear pre-tensioner... or the SRS resistance check is mimicked by a dummy resistor in the circuit. Post up some pics of the "Reel" you found for the rear seatbelts...is it anything like this pic I included earlier which has the pretensioner as part of the seat belt "Reel" assembly.
Kukkakeppi
x 7
Reel was the same as in your picture, but without any wires in it... It seems like in Finnish models, there usually were no rear pretensioners in Clio 2.
AI also suggested that there could be dummy resistors, but where to find those in my Clio, that is a mystery. I could also buy resistors from local electronics shop, but then also in that case, I should find the right wires near ecu :)
https://partco.fi/tuote/metallikalvovas ... 2kohm-8976
Also AI tells this:
In 2003 Renault Clio II (Phase 2) models imported to Finland, rear seatbelt pretensioners were virtually non-existent in the standard models.
Here is how the equipment levels were split in the Finnish market:
Models WITHOUT rear pretensioners (Most common Finnish cars)
By far the most sold Clio trims in Finland were the Authentique and Expression (usually equipped with 1.2L or 1.4L engines).
-These base and mid-tier models did not have rear seatbelt pretensioners.
-The standard safety package for Finland included front seatbelt pretensioners, front airbags, and side airbags (Renault's SRP system). Rear pretensioners were not included in these budget-friendly trims, even in the cold-climate packages tailored for Finland.
Models WITH rear pretensioners (Rare premium and sport versions)
Pyrotechnic rear seatbelt pretensioners (on the outer rear seats) were reserved only for the top-of-the-line and sporty variants. You will find them if the car is one of the following:
Clio Initiale: The most luxurious trim featuring leather seats, wood trim, and the maximum safety configuration.
Clio Renault Sport (RS 172 / RS 182): The hot-hatch version powered by the 2.0L engine.
Custom factory orders: They could technically be ordered as an optional safety pack for mid-tier trims (like Dynamique or Privilège), but this was extremely rare for cars pre-configured and stocked by Finnish dealerships.[/i]
Kukkakeppi
x 7
So, now I have this weird problem, no rear pretensioners, but I have a fault code for them. If anyone have a solution here, I would appreciate. :) Thanks!
Hi Kukkakeppi...
Do you have a wiring diagram for the Airbag System on your car? If not this manual does have a diagram with it which includes wiring colours and details of the SRS ECU pin numbers (Chapter12 Diagram2), and importantly a page of dire warnings about precautions necessary in relation to any investigations into the Airbag and Pretensioner Circuits to prevent potential triggering of the airbags or pre-tensioners. (Chapter 12 Section 27 Airbag System -general information and precautions)
Readily available on the net via amazon e-bay and other sites/private sellers
for example https://www.amazon.co.uk/Renault-Clio-P ... 174&sr=8-3
With the wiring diagram you will be able to identify the pin numbers relating to the Rear Pretensioner Circuits which are throwing up your Trouble Codes, and trace the wires back from the SRS ECU to where they terminate. There will be two numbered pins in the SRS ECU Multiplug for each rear pretensioner, from which two wires will lead away to supply each of the two rear pretensioners. (yes yours don't exist but the wires will presumably)
Kukkakeppi
x 7
Thank you! I found this manual from my public library, now I just have to wait to get it. I will get back to this, as soon as I get the manual. Thanks again, I appreciate your help!
Kukkakeppi
x 7
No luck with manual, there wasn´t much about airbag wiring.
I have tried to use Renolink and Ddt4all to remove pretensioners, because there is no pretensioners in my car, but now I get fault code 9044: Configuration lignes de mise a feu.
Is there any way to remove that fault code by using either Renolink or Ddt4all. As it hasn´t been difficult enough, everything is in french in Renolink and Ddt4all...
Kukkakeppi
x 7
I got some help from Finnish Renault site, and I think I solved it! I opened the airbag ecu connector, and there are four wires, and those wires are attached to small light bulbs, which are used as resistors. One wire was loose and other one also little so and so. I will now use new resistors and I´m sure it will work. Thank you for your help!
Update: Yes. Light is now off. Problem solved. :)
Here are pictures of this
1098 and 1097 are passenger pretensioners.
Kukkakeppi wrote: 01 Nov 2026, 14:02 Update: Yes. Light is now off. Problem solved. :)
Threads which conclude with a success should be celebrated! Well done Kukkakeppi!
Maybe a couple of pics to show what you discovered ie pics to show the wires from the ECU pins for the non existent Rear Pretensioners terminating in the "light bulbs" and your subsequent fix with the resistors.
Possibly at some point the SRS ECU has been replaced in your car with a replacement from a vehicle which had rear pre-tensioners. I cannot imagine your car came out of the factory when new with the "light bulb" termination of those wires from the SRS ECU.
The manual I referred to previously does have a wiring diagram, which shows pins 16/41 and 17/42 as being the pins where the wires for each of the Rear Pre-tensioners originate/terminate at the SRS ECU.
