Hello,
I am trying to diagnose an ABS/ESP issue on my 2009 Peugeot 207 CC 1.6 HDi.
VIN last 5 digits: 25762
Diagbox previously showed the following ABS fault:
U1221 – Fault absence of communication with the electric power steering ECU
* Status: Permanent fault
* Characterisation: Data invalid
At the time the fault was stored, the ABS ECU supply voltage was showing only 7.4 V.
Later, in live data, the ABS ECU Supply voltage was around 8.8–10.4 V, while the BSI and battery voltage were normal.
Multimeter readings:
* Engine off: 12.47 V
* Engine running: 14.44 V
So the battery and alternator charging voltage appear normal.
I also checked the engine bay fuse box. It is completely dry, with no obvious water ingress, corrosion or oxidation.
According to the maxi-fuse chart:
* MF2 – 20/30 A – ABS/ESP pump
* MF3 – 20/30 A – ABS/ESP solenoid valves
* MF10 – 80 A – Electric power steering
The relevant fuses and holders look physically clean, and I will also check them for voltage drop.
The car drives normally and I do not constantly get an ABS/ESP warning while driving, but I am not fully sure whether the ABS is actually functioning correctly.
I am considering the following possibilities:
* ABS ECU/pump unit may have been replaced previously and not correctly telecoded.
* Electric power steering ECU/rack may have been replaced and not correctly configured.
* Voltage drop in the ABS ECU power supply, connector or ground.
* Internal fault in the ABS ECU voltage sensing circuit.
The engine ECU also previously stored:
P0704, P1351, P0299, P1435, P1434
Has anyone seen this combination of U1221 + low ABS ECU supply voltage on a Peugeot 207?
Also, if the ABS unit or electric power steering unit has been replaced, does it require Diagbox telecoding/configuration or calibration?
Any advice on what to check next would be appreciated.
Thanks.
Peugeot 207 CC 1.6 HDi 2009 – ABS/ESP U1221
Huskyxantia
- x 925
Re: Peugeot 207 CC 1.6 HDi 2009 – ABS/ESP U1221
I had a 206cc same thing my problem was the loom from the abs pump had 5 wires exposed due to road grit and they would touch now amd again then the faults would come up on the display . I cut the bad out then soldered the joints back together then covered them in black waterproof tape , problem sorted
Husky.
Radaresat
I think this connector is supposed to look like this; it seems to have some kind of protective coating or material on it. At least, that’s what GPT says.
I checked the top and bottom points with a multimeter and couldn’t find any break in continuity. However, the battery voltage drops as low as 8.77 V while cranking.
Tomorrow I’m going to check it with Diagbox. Also, I couldn’t find the MF9 and MF10 fuses.
![Image]()
Radaresat
I did a more thorough check and found that the ground connections were very poor. I cleaned them, but it’s already late now, so I’ll continue checking everything tomorrow.
Huskyxantia
- x 925
That yellow wire in the loom looks spilt undo the back tape around the loom check each wire without the tape on that's how I found my problem
Husky.
Radaresat
I am confident that the car's battery is in very poor condition. I am getting code U1331 along with a power steering fault. I tried to recode it, but couldn't find the option in DiagBox. There is also no communication with the ESP module, and everything is a mess right now. Do you think I need to buy a new battery? I checked the cables and they are intact.
Reason: Images corrected
Radaresat
Today I installed a new battery. I also replaced the relay and the relevant fuses. The BSI was configured for a 42 Ah battery, but the new battery is 64 Ah, so I changed the battery setting to 64 Ah using Diagbox.
With the engine running, the BSI shows around 14.9 V and the electric power steering ECU shows around 14.0 V. However, the ABS/ESP ECU only shows around 9.9–10.1 V in live data.
There are currently no active faults stored in the ABS/ESP, and during the actuator tests I can hear the pump and valves operating. However, the electric power steering ECU still stores U1313 – no communication with ABS/ESP / incorrect data received. The “Power steering status” also sometimes changes by itself between Activated and Deactivated.
My main question is: if the BSI and power steering ECU are seeing 14–15 V, but the ABS/ESP ECU only reports around 10 V, does this suggest a real power supply/ground problem to the ABS unit, or could Diagbox be reading the voltage incorrectly? Could this also be the reason for the U1313 fault?
I don’t have much experience with automotive electronics, so I would really appreciate any advice on what I should check next. If anyone knows of a useful video or guide showing how to diagnose a similar ABS/ESP power supply or communication problem, that would also be very helpful.
