Peugeot speedo cable
Barney00731102012
Unread post by Barney00731102012 »
Hi All
Really hope someone can help as I’ve searched absolutely everywhere, I think, I’m trying to find a brand new Peugeot or Fiat rubber peg which holds the speedo cable into the gearbox. I’ve found a secondhand one but I believe when there used they get perished and get loose and fall out.
x 8114
Re: Peugeot speedo cable
Are you referring to one of the parts shown in this picture of a Boxer's speedo cable? :)
https://www.autopartspro.co.uk/rms-22274578
Barney00731102012
Hi
Had a look at what you mentioned unfortunately no that’s not it, I’ve got a picture of what I need, but as I’m rubbish with computers I can’t work out how to get it on here, I will seek advice on this.
x 8114
This guide will help: :)
viewtopic.php?p=516529#p516529
Barney00731102012
Ok this is what I’m after New not used.
Barney00731102012
I used to be a speed boat, but now I’m bu bu bu bu better!
x 1459
Unread post by xantia_v6 »
The part number is 265007, but they don't seem to be available anywhere. For the purpose of holding the speedo cable I imagine that you could use a screw and nut, but it would probably leak oil, but a couple of blobs of silicone sealant may fix that.
https://citroessentials.com/product/265 ... n-peugeot/
Barney00731102012
Brilliant thanks for the information ie; part number etc, it’s like trying to find the Lochness monster.
x 1942
Unread post by Paul-R »
Nah, people have seen the Loch Ness monster.
