Hi All
Really hope someone can help as I’ve searched absolutely everywhere, I think, I’m trying to find a brand new Peugeot or Fiat rubber peg which holds the speedo cable into the gearbox. I’ve found a secondhand one but I believe when there used they get perished and get loose and fall out.
Peugeot speedo cable
- x 8080
Re: Peugeot speedo cable
Are you referring to one of the parts shown in this picture of a Boxer's speedo cable?
https://www.autopartspro.co.uk/rms-22274578
Barney00731102012
Hi
Had a look at what you mentioned unfortunately no that’s not it, I’ve got a picture of what I need, but as I’m rubbish with computers I can’t work out how to get it on here, I will seek advice on this.
- x 8080
Barney00731102012
Ok this is what I’m after New not used.
Barney00731102012
I used to be a speed boat, but now I’m bu bu bu bu better!
- x 1441
The part number is 265007, but they don't seem to be available anywhere. For the purpose of holding the speedo cable I imagine that you could use a screw and nut, but it would probably leak oil, but a couple of blobs of silicone sealant may fix that.
https://citroessentials.com/product/265 ... n-peugeot/
