Electric park brake problem
piffpaff34
Unread post by piffpaff34 »
Hello mates.
I'm from Germany and recently I bout a 2008 C4 Picasso manual shift. The seller informed me that the EPB doesn't work. Dashboard shows the P, "Auto P" and ESP lamp, but not ABS lamp (it's working).
I did some research but I only found posts talking about EPB problems with lighted ABS lamp.
My recent research brought up that there might be a possible fault of the clutch pedal sensor. Is that a possible explanation for this error or do I have to be afraid of a way more expensive error like EPB ECU fault?
Diagnosis (Bluetooth Dongle) shows U1219, nothing else.
Thanks in advance for your replies and effort.
Regards from Germany
Pascal
x 8119
Re: Electric park brake problem
Hi and :welc:
I don't know if this will help but a read through this website may give you some ideas: :)
https://www.engine-codes.com/u1219.html
piffpaff34
Thanks. Not that doesn't really help because I really don't think that the C4's ECU has a HDD...
x 1487
You probably need a better scan tool so you can interrogate all the ECUs. These are notorious for putting the handbrake / ESP lights on for faults that are nothing to do with the handbrake!
