Citroen Jumpy/Dispatch 2017
bulletbolt
Unread post by bulletbolt »
Hi all,
I am having few issues with our van and investigation is getting difficult..
1. There was battery sign on the dash indicating no charge. This was confirmed by low system voltage when engine running. The alternator was in bad shape regardless so I replaced with new NK unit. However, the light is still on and diagnostics reporting LIN network fault U1400 which refers to LIN network. I will attempt to see if there's any signal on this line but was wondering if anyone have wiring diagram for this circuit?
2. Multiplexed additive pump fault - reported two faults in ECU, P1434 and P1435. The pump itself reports no fluid. I have ordered top-up kit and used approx 0.5 L of it, then overflow was indicating tanks is full. I have ebay Lexia tool and 9. something Diagbox, but when I go to additive pump maintenance, there is no option to 'reset refill' or similar funciton. There is one in the engine ECU section, but after using this feature the level reported by the pump is still 3%, and all faults remain present. Anyone have any ideas with this? I am due to order different tool to see if that helps, but my Thinkdiag carried out same procedures as described and it didn't work either..
The VIN of the car is VF7**************[VIN obfuscated, can be read by forum staff]
Any help much appreciated.
x 8128
Re: Citroen Jumpy/Dispatch 2017
I'm wondering if the indicated network fault is preventing the engine ECU from talking to the pump and hence doing the reset in the Engine ECU is not communicated to the pump. I'd start by going through all the connectors at the ECUs and anywhere in circuit to ensure you have no corrosion or bent pins etc. Once you are happy with the wiring then a Diagbox global scan is probably the best next move. Good luck :)
bulletbolt
Mick, thanks for your reply.
I have spent some time today, purchased Haynes online manual, but it's so bad I have no confidence in the detail of it at all.
Investigated alternator LIN network, according to Haynes, it should be direct connection from alternator to ECU conn. B pin 31 - no continuity found. However, in Haynes website, if you follow trouble-shooter, it suggests there is inline connection and a splice (to be confirmed). There's also chance the ECU pin is completely different. Strangely when started the battery was charging at 14.2V so assume there was some sort of connection somewhere. After erasing fault in the ECU it didn't come up again.
But then, the multiplexed pump started to fail communication all together. A little lost now. If anyone had anything similar, please share knowledge..
Peter Palmer
x 12
Unread post by Peter Palmer »
I had the multiplex fault for ages on the same age van, I tried everything in diagbox to reset it / fill it / tell it it had a replacement etc. and no still no joy. Diagbox kept saying the tank was empty and it had a multiplex ECU faut no matter what I did. In the end I bought a second hand tank of Ebay for £60, plugged it in and the fault cleared itself without ever using diagbox to reset it.
Interestingly a while a go I read on here about another similar fault and the poster was saying he had 2 ABS faults show up as well as the multiplex fault but when he unplugged the tank the ABS faults cleared, that was my exact scenario so when the multiplex ECU gets corrupted it must drag other stuff down on the network as well. Maybe the multiplex fault is causing the charging error to show, I'd start with that.
