Speedo cable oil leak
Barney00731102012
Unread post by Barney00731102012 »
Hi All
I’m hoping someone else has had this problem, ok I’ve got a Peugeot Boxer 2001, and I’ve noticed whilst fitting a new speedo cable that oil is leaking around the plastic retainer which goes into the gearbox, I’ve fitted a new rubber O ring seal thinking this will do it unfortunately not , so I thought I’d ask on here as people has helped me a lot in the past with advice.
x 8036
Re: Speedo cable oil leak
This post is about a similar problem on a motorbike gearbox, it may give you an idea or two. Good luck: https://www.bsaownersclub.co.uk/forum/i ... ic=19367.0 :)
