I'm going to change the timing belt from my peugeot expert 2.0 Blue HDI 180Hp. Does anyone have the correct torque settings for the crankshaft bolt?
Thanks in advance,
Regards,
Patrick
Torque Crankshaft pulley bolt 2.0 bluehdi 180hp
Genderen
windy1603
- x 10
Re: Torque Crankshaft pulley bolt 2.0 bluehdi 180hp
Tighten to 7daNM then angle tighten 110 Deg is the offical torque. When removing the bolt due to threadlock it can be tight PSA recommend using a heat gun on the bolt to soften the threadlock if it's stuck.
They also state that impact guns should not be used (I personally have used 250NM impact gun most times to remove and fit the bolt with no issues but there is a risk of snapping the bolt) on the Family cars 3 x 2.0 HDI's I normally start with a hot engine then whip the top cover off set timing and pin the cam/crank and loosen the nut while hot so the threadlock is softened then go and have a coffee let it cool down and then start belt change
- x 2341
Just checking= loosening crank pulley bolt whilst timing pins in place?windy1603 wrote: 19 Aug 2026, 19:22 start with a hot engine then whip the top cover off set timing and pin the cam/crank and loosen the nut while hot
(To my knowledge that isn't recommended - presumably as puts stress on the pins)
windy1603
- x 10
Timing pins in place and also the flywheel locking plate (One like this https://www.amazon.co.uk/dp/B0DM1P3KFP)
- x 2341
Ah yep, that's best thing for flywheel locking. Am sure I've read to remove timing pins (i.e. only that crank locking tool in place) when undoing the crankshaft bolt - will try and find a reference.windy1603 wrote: 20 Aug 2026, 07:10 Timing pins in place and also the flywheel locking plate (One like this https://www.amazon.co.uk/dp/B0DM1P3KFP)
Genderen
Thanks for the info, job done now!
