Reverse gear diagram
Onur52
Unread post by Onur52 »
Hello everyone, I am writing from Turkey. The reverse light switch wire on my vehicle was cut previously, and I cannot find the correct wire. I need the wiring diagram or details for the reverse light switch circuit. Thanks.
My car: Citroen c5 1.6 hdi 110 2010 models
x 8144
Re: Reverse gear diagram
I have assumed a manual gearbox as you didn't say. This is the PSA PDF for your reversing lights: Good Luck :)
C5 X7 reverse lamps.pdf
C5 X7 Reversing lights for manual gearbox car
(2.32 MiB) Downloaded 19 times
Onur52
Ynt: Geri vites diyagramı
Yes, I am Turkish and I don't speak English.
Yes, my car is manual.
Thank you very much; you have been very helpful.
Onur52
I have one more question: this connector is located under the BSM, and the dark blue wire has been cut. What is the function of this connector? Could you also send the wiring diagram for it? I want to reconnect the dark blue wire.
x 8144
If you can read the numbers on the connected wires I may be able to identify a diagram with those on it and hence find the connector and then the cut wire. I cannot do it tonight as my system is not available in the evenings but I'll have a look tomorrow if you can identify the wire numbers. :)
Onur52
Could you send the wiring diagram for the MAF sensor connector? I couldn't read the markings on the wires.
Onur52
The wires from the connector in the photo go to the MAF sensor.
x 8144
The diagrams are very fuzzy on my system but this is the PDF of the injection system and a print of the bottom showing the MAF sensor. Good luck
c5 x7 injection.pdf
C5 X7 Injection
(797.56 KiB) Downloaded 15 times
MAF location
MAF location
Onur52
Hello again. I took a photo of the numbers on the cable; I wonder which line these cables belong to?
Onur52
1410 purple
1810 white
1910 green
1310 cream
