No crank, no start
ASA
No crank, no start
Unread post by ASA »
No crank, no start!
Citroen Jumpy, 2018, 2.0 BlueHDi 180 DW10FC, 211k
Out of blue stranded in a car park.
Battery 6 months old and has juice.
Codes:
B1805-62 present Starter motor fault-coherence
P0215-71 permanent Principal relay control-Relay stuck
P16D8-00 permanent starting and switching off of the engine controlled - Starter control line faulty
New starter or dig deeper? :-k
x 8100
Re: No crank, no start.
If you search in the Citroen forum for 'Jumpy no start' you will find a number of threads about this and you may get an idea :)
ASA
mickthemaverick wrote: 21 Jul 2026, 07:51 If you search in the Citroen forum for 'Jumpy no start' you will find a number of threads about this and you may get an idea :)
I will go through them right away. Thanks!
*edit. Went through all of them plus searched all the DTCs too.
What I found is that it could be the starter itself or BSM... Unfortunately no exact match for my symptoms. So all info is much appreciated O:)
ASA
A new BSM is quite affordable. And learning them being quite fault prone, a new one wouldn't hurt in the long run... Does BSM need coding when replacing?
ASA
This was a faulty starter motor.
x 1940
Unread post by Paul-R »
Thanks for letting us know.
