(I'm in the States)
I may need to pull the pan off my GSA engine and I'd like to be ready with a new gasket if needed. I have no signs of leaks, so this might be overkill.
Does anyone supply them? Or is it all NOS?
Cheers,
Bruce
Seeking GSA oil pan gasket
- x 8111
Re: Seeking GSA oil pan gasket
Hi Bruce and
With your pretty rare use of the engine in your Trihawk it will be difficult but you could try contacting these people: https://shop.citroenclassics.co.uk/citr ... s-24-c.asp Good luck
- x 1487
Welcome along!
I don't think this engine has a removable oil pan (sump over here!) - as it's a boxer engine it uses a split casing design. If you want to get in there, you need to fully dismantle the engine and then split the casing. What's up with it that you think you might need to go in?
Stonehopper
- x 118
You have no signs of leaks.
Congratulations! But if oil does appear beneath the car, look at the oil drain tubes from the heads, and the rocker covers.
Derek
- x 1069
Try these guys https://www.chevronics.co.uk/
Champion of Where's CitroJim
