Battery draining problem
gsc1ugs
x 3
Unread post by gsc1ugs »
See the two pics, ignition off and faint light on a few on the instrument symbols, after 5 hrs battery is flat, not sure how to find the fault#
one pic battery lead on, the other removed
x 8086
Re: Battery draining problem
It would appear that you have something not turning off properly when you switch off. The first thing I'd do is a BSi reset following the procedure in the link below. If the fault is still present after that you will need to isolate which circuit is still active, possibly by removing fuses one by one until the fault clears. Most times this type of failure is due to dampness or corrosion in a connector somewhere so check all the fuseboxes for those issues and see what you find. :)
viewtopic.php?p=601679#p601679
gsc1ugs
x 3
I will try BSI what i dont get is they are so separate in their functions, ones airbag , saatbelt clip, fuel empty light doesn’t make sense
x 8086
There may well be a multi-plug on the fusebox that carries all those circuits and has been infiltrated by damp or something. :)
admiral51
(Donor 2026)
x 391
Unread post by admiral51 »
I cannot see the fuel low level light in the pictures unless i am not seeing the obvious which is something i am well known for.
Is the AirBag light for the passenger side? Both of the seatbelt/airbag lights are close together so could be light bleed if very faint but could be on a similar circuit for the ECU ?
To drain the battery in 5 hours is a heck of a drain. Have you checked earth strap points?
Just throwing out some thoughts, not technically qualified but i have owned a various number of Citroens 🙈🤣
gsc1ugs
x 3
I did check battery earth strap also put a jump lead earthing separate lights still on very faint
gsc1ugs
x 3
mickthemaverick wrote: 15 Jul 2026, 14:44 It would appear that you have something not turning off properly when you switch off. The first thing I'd do is a BSi reset following the procedure in the link below. If the fault is still present after that you will need to isolate which circuit is still active, possibly by removing fuses one by one until the fault clears. Most times this type of failure is due to dampness or corrosion in a connector somewhere so check all the fuseboxes for those issues and see what you find. :)
Can someone condense this BSI reset because some of it i dont understand
Boot? Its a van, motorised function whats that?
x 8086
The terms you mention are in the subsection headed:
For C5 X7 Tourer V6 Engines, with / without motorised tailgate or vehicles where the battery is in the rear boot:
So don't apply to your van.
gsc1ugs
x 3
Call me thick but still no idea - boot doesnt have a lock
x 8086
Since the only vehicle mentioned in your signature is a DS3 it would be sensible to confirm the full details of the vehicle you are talking about :)
gsc1ugs
x 3
mickthemaverick wrote: 16 Jul 2026, 11:38 Since the only vehicle mentioned in your signature is a DS3 it would be sensible to confirm the full details of the vehicle you are talking about :)
Oops thanks for reminding me will edit now
2013 citroen nemo 1.3 diesel sorry
PaulC5
x 675
Unread post by PaulC5 »
This car is keeping you busy. A link to your previous battery being drained topic viewtopic.php?t=89112
gsc1ugs
x 3
oops forgot about thT
admiral51
(Donor 2026)
x 391
Totally random thought but interior lights are i guess one of the things that wake up first when unlocking the vehicle. A cheap first experiment would be to remove all of the interior bulbs( including those in the boot area ) and see if the drain is still there. If the drain is still there i would then still leave them out and remove all of the rear light bulbs, including number plate ones and see if the drain is still there.
A blown bulb can short to earth and become a right PITA.
Colin
gsc1ugs
x 3
Tried bulbs didnt do anything, how many earth straps are there on vehicle? I need clean them all, its sounds like a bad earth because none are linked together, fuel warning light, airbag indicator seatbelt clip ?
