Oh No!! Major disaster!!!
FloRida
Unread post by FloRida »
So trying to check why my wing mirrors were not folding, and in testing I accidentally shorted the folding mirror connector at the passenger door. Now my car won’t start !!!
I’m getting multiple error codes on diagnosing saying some ECU cannot be connected :( too, abs failure, engine fault, canbus cannot be connected.
I’ve disconnected the battery for a couple of hours to try to reset the bsi but nothing changed. Tried to erase the faults but no luck.
Have I completely screwed something up? :(
Please can anyone help :idea:
furriegurrie
x 37
Re: Oh No!! Major disaster!!!
Unread post by furriegurrie »
I’d start with carefully checking all fuses. Best is to measure continuity with a meter instead of just visually checking them.
FloRida
Thank you for your reply, did some digging with a multimeter and found that F13 in the engine bay was blown, swapped it out and the car now works again! That was stressful !
x 1976
Unread post by Stickyfinger »
It says something about modern wiring systems that when there is a fault with a wing mirror your car can be disabled :)
PaulC5
x 614
Unread post by PaulC5 »
A look in a handbook for the 2012 DS3 gives this for F13
F13 40 A Built-in systems interface supply (ignition positive).
x 1976
PaulC5 wrote: 10 Jul 2026, 21:41 A look in a handbook for the 2012 DS3 gives this for F13
Flippen heck,,,,wing mirror connected direct to that !...did Lucky Lucas emigrate to France ?
