I can't find my Relays
anialfred
Unread post by anialfred »
I wanted to diagnose ac faults but can't find where the car relays are I found two fuse boxes but no relay, please help
Citroen c3 picasso 2010 diesel ⛽
Alfred
x 1487
Re: I can't find my Relays
Likely they are integrated into the fuse box under the bonnet. First thing to check is has it got gas in it, and is the computer seeing the pressure?
Sloppysod
x 396
Unread post by Sloppysod »
Does the a/c pump engage when energised?
Not sure about Citroën, but had problems with my Wifes Corsa, the A/C only works when the heater fan is running, does your fan work. ?
Stu 🏴󠁧󠁢󠁷󠁬󠁳󠁿
anialfred
Thanks for the reply,
The pump doesn't kick in when ac button is pushed, I normally hear click like relay and pump engagement but not anymore, even the rpm don't react. The blower fan still works.
Alfred
PaulC5
x 682
Unread post by PaulC5 »
At 16 years old if it has never been regassed then chances are it needs to be done as it gradually leaks out over time.
x 1487
The click you can hear is the clutch engaging on the AC compressor. As Paul says it's very likely low on gas which means the ECU won't send the signal to engage the compressor. Get it regassed first and take it from there.
Sloppysod
x 396
Note: if it's been dry for a while the seals may have deteriorated, so if you get told that then expect it. Not sure if you can still by regassing kits from Halfords, it may be worth asking.
Stu 🏴󠁧󠁢󠁷󠁬󠁳󠁿
anialfred
It was refilled when it stopped working also leak tested and came back ok but still not working, the ac workshops are very busy can't even get appointment. But YouTube said I should try changing the pressure switch which I have ordered, once it's in I will give you guys update
Alfred
x 1459
Unread post by xantia_v6 »
If it has the correct amount of refrigerant then you really need to get diagnostics read from the BSI and engine ECU firstly to look for fault codes that would disable the compressor and secondly to check the values of sensors and switches.
anialfred
Pressure switch changed today and still not kicking in also no fault code is coming up,
x 1459
Then you need to read the live data from the BSI and engine ECU to trace the problem. Check that the AC control switch is detected and that the engine ECU is not inhibiting operation.
