Hi guys hope you are well,
I have 2009 citroen C5, the thing is my passenger side wiper sticks in the upright position when turned on, then returns to resting when I return to the car after a short while when I unlock the car.
I have checked the motor magnets etc on the passenger side and greased seem ok and was clean inside. The wiper motor works when the wiper is removed, I am at a loss guys. Could it be the drivers side motor.
I thank you all in advance
Turfite
Strange wiper problem
- x 1941
Re: Strange wiper problem
How old is the battery?
Have you tried doing a BSI reset? viewtopic.php?p=601679#p601679
Turfite
Hi thanks for reply I have doeveel BSI resead the battery is new
Turfite
Turfite
PaulC5
- x 697
Wiper failure on the C5 X7 is common, there is a long topic here to read viewtopic.php?t=59504&hilit=c5+wipers
Turfite
Thank you for the replies folks it is appreciated,
M keyfob seems a bit dogy do you think this will affect the BSI reset to put my wipers back to normal operating as the wiper motors ar very high priced.
Thank you
Thank you
Turfite
no not key fob wiper passenger side sticks in upright position after one sweep and when I leave car and return goes back to normal when I open door
PaulC5
- x 697
Are you touching the wiper stalk after you remove the key, this is used to put the wipers in the upright position so they can be worked on. Should be something in the handbook.
Turfite
Regarding the wiper motor its a good picture but with all due respect and not wanting to cause any ill feeling I cant understand what was written could anyone explain to me regarding where the wiper magnet should be positioned
with respect
Turfite
with respect
Turfite
Estately
- x 22
Hi Turfite,
Here goes. The magnet sits on the shaft that comes out of the motor and has the worm gear on the end and drives the white plastic geared wheel.
For some reason, I think heat build up in the motor as the grease dries out, causes the magnet (red diamond and yellow line on the picture) to move a short distance along the shaft.
So what, you may say.
Well the magnet interacts with the circuit board inside the case and if the magnet has moved by only a small amount along the drive shaft, communication fails. The wiper system cannot locate the position of the wiper driven by that shaft. The wiper then hopefully parks either vertically or horizontally at the bottom of the windscreen to stop the other wiper colliding with it.
Of course the circuit board can fail if it has become damp, the magnet position is then not the issue.
If the circuit board looks ok, the fix is to lever the magnet back to the correct position along the drive shaft. Mine was very stiff, from memory the drive shaft had a series of small flats on it so was not perfectly round so you are moving the magnet in a plastic case along not round the drive shaft.
You will see some discussion of the best fixing means to "stick" the magnet on the shaft to prevent movement occurring again. Sealing and dryness of the motors is also important.
Similarly UK right hand drive C5 models drivers side motors are the master and both wipers fail if the issue is with the driver's side, then if the passenger side motor stops the driver's side will keep going and you still have very good vision in wet conditions.
If you can follow the forum descriptions to get the wipers going again you can save your self a considerable sum of money.
Hope that helps.
Andy.
Hope that helps.
Andy.
If it can happen it will.
Turfite
Hey Andy thats great thank you it is working but stops then goes judders is there a alignment line on the plastic cog please
Thank you for your help
Turfite
Turfite
Estately
- x 22
To the best of my knowledge there is no alignment line on the plastic cog.
I would clean and grease the parts in the case together with wiper spindle where it passes through the case.
I do not recall the magnet alignment as being difficult. I would take both motors off for internal cleaning of the cases, then you can compare the magnet alignment with both motors and the pictures.
As a test just loosely assemble the motors and plug the electrics in without bolting them up - wipers not connected.
Switch them on and you will see how the wiper shafts are moving. You can also check the connections of the plugs and clean up if necessary.
By motors I mean the die cast case not the attached black round case that contains the windings and brushes etc.
The wiper arms are aligned on the shaft once you have fully reinstalled both motors. There is a mark at the bottom of the winscreen where the blades lie when at rest.
With the motors removed give the area below a good clean, make sure it drains and ensure that the plastic cover is in place above the motor. You want to reduce the possibility of dampness in the vicinity of the motors, caused by leaves, straw and mold, particularly if you regularly park under trees. Ironic that a wiper motor assembly doesn't like wetness.
Hope that helps.
Andy.
Hope that helps.
Andy.
Turfite
Yes the mechanism under the die cast cover is really stiff cant move by hand to get grease to the workings may have to use molegrips or somthing anyway thank you again
Turfite
Turfite
