Engine Oil Colour
soundlovers
Engine Oil Colour
Unread post by soundlovers »
I have a question, has anyone encountered this before?
TU5JP (NFU) engine, I change the oil regularly every 10,000 km including the filter. I use Total Quartz 9000 5W-40.
It has happened to me several times that the drained oil is not the classic black, but has a distinct reddish-brown to reddish colour (see photo). When I drained the oil and a little of it got on my hand, it almost looked like I had blood on my hands.
I wondered if someone before me had used some kind of oil additive (some are red) and since a small amount of old oil always remains in the sump, it could also colour the new one. But I'm not sure.
What surprised me the most - after the change, I poured new oil, started the engine only for a moment to check the level and after this short run, the new oil on the dipstick was clearly reddish.
On other cars I've serviced, new oil usually stays light amber for a long time after starting, so I'm surprised.
Has anyone else experienced this with a TU5JP/NFU engine? Is this colour normal, or could it indicate an additive, oil reaction, or other problem?
Thanks for all the experiences.
x 8111
Re: Engine Oil Colour
You certainly have some sort of contamination there. It could be as you suggest the result of an additive, it could also be an unwanted mixing of coolant and oil if you have an oil cooler for example which has a leak. Another red fluid around is power steering fluid but I can't really see how that might mix. I would suggest you try a full engine flush with proprietary flushing oil on your next oilchange and see if that clears it up. :)
https://www.ebay.co.uk/itm/267691580171
soundlovers
Thanks for your opinion.
I think I can rule out coolant contamination – the coolant level doesn't drop, there is no milky emulsion in the oil, and there are no other typical signs of coolant mixing with the oil. Power steering fluid also seems very unlikely, as there is practically no way for it to enter the engine's lubrication system.
I've been using the same oil in this engine for several years, and this happens after every oil change. What's interesting is that I have another KFX engine running on LPG with exactly the same oil, and it has never shown this behavior.
That's why I contacted TotalEnergies technical support directly. They also acknowledge that nitration or a reaction of the oil additives during LPG operation could be a possible explanation.
x 1069
Unread post by Rp0thejester »
Firstly it's spelt, colour,(sorted!), bliming American predictive texts. The only other fluid that's red is gearbox oil which I doubt. It may well be too much additive in the fuel which, if the O rings are worn, could penetrate the oil.
PaulC5
x 681
Unread post by PaulC5 »
A search suggests turning red is common if engines run on propane (lpg) but you have not said it runs on anything other than petrol so not that. When you change the oil do you drain it or suck it out ? Sucking out may leave more of the old oil behind. You could send a sample off to a lab to be analysed.
x 2003
Unread post by Stickyfinger »
Well, you learn new every day.
x 5674
Sure they didn't mean red diesel?
shtu
x 76
Unread post by shtu »
It's a puzzle with no obvious answer.
If it's a concern, I'd be tempted to buy a LARGE container of cheap diesel-spec 5/40, change the oil several times in quick succession, then return to the correct spec to finish. You never get all the old oil out of an engine, regardless of how you drain it, so changing it a few times would be a way to dilute whatever it is.
Something like this - https://www.ebay.co.uk/itm/377253193219, real cheap stuff for the flush. (suppose you could add an engine flush as the very first step before changing it)
If you're handy with the spanners, take the sump off and clean it and the pickup out, help remove some more.
Flipside is if someone has filled it with snake oil for a reason, you're getting rid of it.
Steve Walsh
x 516
Unread post by Steve Walsh »
Without wasting money on oil changes and flushing I would have it analysed and find out from the experts as to what is in your oil.
https://www.oilsampling.co.uk/store/Eng ... p170994399
soundlovers
I want to remove the oil pan, but I'm worried about the screws holding the exhaust and catalytic converter, it's a 2006 Berlingo, so I don't break the screws on the exhaust flange, otherwise I probably won't be able to get the oil pan out..? Does anyone have a trick for the oil pan - it will be well glued to the engine block.... thank you very much
Mihael_M
x 37
Unread post by Mihael_M »
It's very strange that the oil gets dirty so quickly with that red liquid. I would still pour WYNNS Commercial Vehicle Oil System Flush into that oil before replacing it. You buy 1 liter, but 0.5 liters is enough for 4 liters. First, you have to remove 0.5 liters from the engine. According to the instructions, it is enough to run the engine for 15 minutes to melt the deposits. It seems to me that you must remove the oil sump-pan and wash it. The sieve-filter on the oil pump must also be cleaned. Removing the oil sump-pan is not complicated.The glue doesn't hold that strongly.I repeat, this is all very strange, but we don't know what was poured.You didn't say what engine it was.
PaulC5
x 681
According to the first post it has 'TU5JP (NFU) engine' which is a 1.6 petrol. Often on the oil dipstick min to max levels are 1 to 1.5 litres so if 0.5 litres of flushing agent is put in chances are the level does not need to be dropped first.
soundlovers
I did another small experiment that I thought might be interesting.
The first photo shows three fresh oils straight from their original containers:
Total Quartz INEO ECS 5W-30
Total Quartz 9000 Energy 5W-40
As expected, all three have the normal light amber color.
In the second photo, I added exactly 20 drops of the used oil from my TU5JP (NFU) engine to each fresh oil sample. Even with such a small amount, all three fresh oils turned a very similar reddish-brown color.
This seems to indicate that the fresh oil itself is not responsible for the color. Instead, the used oil contains something with a very strong coloring effect that immediately changes the color of any fresh oil it mixes with.
The question is what exactly causes this. Is it simply a normal chemical change in the oil's additive package (antioxidants, detergents/dispersants), dissolved engine varnish, oxidation products, or something else?
I have contacted an oil analysis specialist recommended by TotalEnergies and sent him all the details along with these photos. As soon as I receive his professional opinion, I'll post it here.
Fresh oil
Fresh oil
old oil added
old oil added
Kelly001
Unread post by Kelly001 »
That's incredible. The fact that just 20 drops of used oil can change the color of fresh oil so dramatically suggests the coloring compounds are extremely potent.
My guess would be that it's a combination of oxidation by-products, dissolved varnish, and contaminants that remain suspended thanks to the detergent/dispersant additives. Color alone isn't a reliable indicator of oil condition, so it's not surprising that a small amount of used oil can dominate the appearance of a much larger volume of fresh oil.
I'm particularly interested to hear what the oil analysis specialist says
x 8386
Kelly001 wrote: 04 Jul 2026, 10:41 That's incredible. The fact that just 20 drops of used oil can change the color of fresh oil so dramatically suggests the coloring compounds are extremely potent.
As illustrated when doing a diesel oil change with filter. Despite the new filter and doing one's best to get as much old oil out as possible, the new oil is very soon black again!
soundlovers wrote: 01 Jul 2026, 14:43 It has happened to me several times that the drained oil is not the classic black, but has a distinct reddish-brown to reddish colour (see photo). When I drained the oil and a little of it got on my hand, it almost looked like I had blood on my hands.
From the photo, that almost looks like used Dexron ATF... Compare with what you might see in a power steering reservoir...
