New to forum
Chrismileham
New to forum
Unread post by Chrismileham »
Having issues with my 2012 3008 1.6 Hdi. Doesn't seem to want to regen. Usd car scanner but the soot and ash levels are not too reliable,as theash reading fluctuates. Used FAP lite as can't get the full version due to lack of developer support, FAP lite reports 675 ltr of eolys fluid in the tank but this amount hasnt dropped since we got the car a couple of months ago.
So now got a lexia coming next week. Also got a dpf clean booked which will perform a forced regen.
I think it has tried to do one but every two weeks the dpf risk of clogging warning appears. Performance is fine, not at all sluggish.
So will probably be on here for advice with the diagbox.
Sloppysod
x 406
Re: New to forum
Unread post by Sloppysod »
Welcome.
Drive your car, at a constant speed, around 45mph for 20+ minutes, so engine gets hot, then the car should do a forced regen.
The eloy tank does not have the same system as a fuel tank, ie float, it is calculated, the ECU knows how much it started with and how much it has used to give what it thinks is remaining.
If you drive a lot of short distances then it will probably use more, long distances where the system gets hot it will use less. That's why it has to be checked by diagnostic equipment every 80,000 miles.
Stu 🏴󠁧󠁢󠁷󠁬󠁳󠁿
PaulC5
x 714
Re: New to forum
Unread post by PaulC5 »
675 litres is a lot, 3 large drums, more than the car boot volume. A full amount might be 1 to 3 litres depending on the car. Have you got the units right ?
Chrismileham
Re: New to forum
No it's 673ml .
Been doing the longish drives at 2200 RPM. We'll see. Noticed on the fap lite app the eolys fluid has dropped slightly but u think it's like ad blue where it squirms a bit in when you refuel. Added an LED to my wing mirror so when it's doing a regen at least my wife or me don't turn the engine off.
ozfrog
(Donor 2026)
x 84
Re: New to forum
Unread post by ozfrog »
Sloppysod wrote: 28 Jun 2026, 07:00 Welcome.
“snipped”
Isn’t that rather slow?
The usual rule in Australia, as far as I know, is 100 km/h for the 20 or minutes. I say, as far as I know, but to be more precise, I should say that it’s what I’ve always been told by Peugeot mechanics.
Cheers,
Andrew
Chrismileham
Re: New to forum
I used car scanner oro and it was saying distance since last regen 359662 miles, which can't be correct. I can't get it to regen. Full tank constant 25 minutes driving at 2200 RPM. Got an appointment to get a forced regen and hopefully they will be able to reset the erroneous numbers.
Sloppysod
x 406
Re: New to forum
ozfrog wrote: 29 Jun 2026, 15:26 Isn’t that rather slow?
Yes and no, my own experience is that 45-50mph is enough, it's the constant engine revs versus speed. However, reading my post I forgot to add keeping the car in a lower gear than normal helps.
Stu 🏴󠁧󠁢󠁷󠁬󠁳󠁿
Germo1963
New User
Re: New to forum
Unread post by Germo1963 »
Brand new to forum - New to Peugeot too!
I have downloaded the appstore, but I cannot install it on my Android phone, any other way to get FAP ELM OBD ?
Cheers
