Fuel Filter replacement - C4 Grand Mk2
CitROeNALD
x 10
Unread post by CitROeNALD »
Is it best practice to remove the fuel filter housing to replace the filter?
The guy in this video removes it completely to clean it and, I guess, open it in an environment where nothing can fall in.
I know the older model required the fuel filter housing to be removed for replacement. But this seems like it could be done without removing the whole thing.
Thoughts?
x 8141
Re: Fuel Filter replacement - C4 Grand Mk2
Personally I would take it out to replace the cartridge. That gives you best access for thoroughly cleaning and fitting new O ring before reassembly. Also be sure to follow the guidelines once refitted to clear the air from the system. :)
CitROeNALD
x 10
mickthemaverick wrote: 26 Jun 2026, 23:17 Personally I would take it out to replace the cartridge. That gives you best access for thoroughly cleaning and fitting new O ring before reassembly. Also be sure to follow the guidelines once refitted to clear the air from the system. :)
Do you just clean externally, or do you pour the fuel out and clean internally too?
Or just do what that guy did and clean externally and pop the new filter into the existing diesel.
x 8141
I'd empty the fuel into a clean jug, take out the cartridge and wipe out the inside. Put the new cartridge in then refill with the jug. :)
Mihael_M
x 37
Unread post by Mihael_M »
Totally wrong and dangerous. It mixed filtered and unfiltered content. In the housing before the filter, impurities and possible water collect, the filter prevents it from passing further into the system. He mixed them in this way. After removing the filter cartridge, the contents must be thrown away and cleaned inside or best washed with water and then wiped with a clean cloth.
CitROeNALD
x 10
Mihael_M wrote: 27 Jun 2026, 07:37 Totally wrong and dangerous. It mixed filtered and unfiltered content. In the housing before the filter, impurities and possible water collect, the filter prevents it from passing further into the system. He mixed them in this way. After removing the filter cartridge, the contents must be thrown away and cleaned inside or best washed with water and then wiped with a clean cloth.
Do you replace the housing empty and let the car purge the system and fill it itself?
Mihael_M
x 37
After removing the filter cartridge, the contents must be thrown away and cleaned inside or best washed with water and then wiped with a clean cloth.The completion can be done in two ways. The first option is to put a new filter cartridge, gasket and connect everything (hoses and cable). then turn on the ignition without starting the engine. Then the low pressure fuel pump in the tank starts working for a short time and then stops. The procedure should be repeated, perhaps 10 times, and then start the engine. If it cannot start, repeat more times. Another way is to pour clean fuel into the filter housing, put the filter cartridge, gasket, mount the hoses, cables and then start the engine.
CitROeNALD
x 10
Mihael_M wrote: 27 Jun 2026, 17:15 After removing the filter cartridge, the contents must be thrown away and cleaned inside or best washed with water and then wiped with a clean cloth.
How meticulous do I have to be with the cleaning? I assume the housing will retain a lot of greasy diesel residue, is water enough to cut through that?
Do I need to be as fastidious as using distilled water?
I also assume it needs to be bone dry before reassembly.
Mihael_M
x 37
There is no need to use distilled water, it is enough to wipe with a dry cloth at the end.
CitROeNALD
x 10
Follow-up question on this:
From what I am reading, all these fuel filters have water drain taps, and this should be bled every service as a check.
But, I cannot find any videos or guides showing someone actually doing this or confirming where the tap drain is on the filter housing.
I think in the video above it (which is the same as my filter) is the thing which is visible on the filter at 4:25 just above his fingers with what looks like a torx slot for opening.
But in general I can't find examples of someone draining this water tap. Is this something that is rarely needed in the UK for our fuels or climate?
I also assume that if I am removing the assembly to clean and replace the filter, it is the same job anyway. But just curious as to why I can't find many guides on it.
(It is actual part of a tick/checklist on mar car's service record, but not sure if they do it)
PaulC5
x 697
Unread post by PaulC5 »
Which engine does your car have ?
I changed the fuel filter on our 2016 1.6 blue hdi Cactus today, easy enough and the third time I have done it. I did not bother watching all the video but it looks similar to the one on our Cactus. Once the filter top is removed I use a Mityvac pump to suck out the old diesel, about 250 ml and then pull out the filter and put it in a plastic bag to catch the drips. I do not bother removing the filter housing and no way think anybody would. When buying the filter I found ones from GSF were not correct and a Bosch N2533 from Eurocarparts was the correct one which has a nozzle on the bottom of it. It was not until I removed it I could tell which filter it needed.
On our C5 I used to open the filter drain each service to let out any water but never found any. On this one the filter came built in to the housing so was expensive. I have not noticed a drain on the Cactus and have not bothered trying to drain any water over the last 9 years. If there is one it could be accessed underneath the housing and not on the top as for the C5.
CitROeNALD
x 10
It's the 1.6 blue hdi 2018. So the filter and housing is the same as that video.
I think the drain tap is there, but very hard to locate in situ hence wondering how often a drain check was realistically done.
I do intend to change the filter though anyway, but will probably follow the proper process and remove the housing too to give it a clean.
PaulC5
x 697
With the top off you can see inside the housing and if you want you can wipe it out. Ours looked clean and running a finger in the bottom did not get it dirty, this was with the diesel sucked out. For the top I do not have a 24 mm socket but a 15/16th inch one fits.
