Quick question.
I don’t have access to the car just now to check this myself & wont get near it until the weekend.
Does anyone know what type of bolt head is used on the calliper securing bolts. Is it just standard hex, or something like Allen or Torx? I’m sorted if it’s hex or Allen, but not so with Torx as I only have a few sizes.
Need to swap a calliper at the weekend and don’t want to fall at the first hurdle.
Cheers.
309 1.8 Brake calliper question
- x 8141
Re: 309 1.8 Brake calliper question
I can't say for your car but I have come across Torx headed caliper bolts on Peugeots which needed a 1/2" drive T55 bit and a big breaker bar. They can be ridiculously tight!!
- x 1470
For buying a single T55 bit, they are sometimes sold individually for ford cylinder head bolts.
- x 8422
Yep, right on both counts... For that reason, only use a very high quality T55 bit. Far too many are made of stale French cheese and are about as much usemickthemaverick wrote: 24 Jun 2026, 16:50 I can't say for your car but I have come across Torx headed caliper bolts on Peugeots which needed a 1/2" drive T55 bit and a big breaker bar. They can be ridiculously tight!!![]()
Also, firmly hammer in the bit to ensure it's fully seated. The percussion will also assist in loosening. Use a long breaker bar.
Gsbx1220
- x 5
Cheers guys.
I'm good to go if its T55. Sure that was the size on my Xantia & definitely the size for Alfa Brembo callipers.
Richard
Gsbx1220
- x 5
Job done. It’s a 19mm hex.
The Xantia of same age I had many years ago was T55.
Maybe this 309 is a bit of an oddity.
Richard
- x 1941
Maybe because the 309 was originally designed by SIMCA and intended to be a replacement in the Talbot range? And SIMCA used 19mm head bolts as a rule?
- x 1496
I have a 1/2" drive impact spec T55 for just that reason, having snapped off the previous one on a stubborn Xantia caliper boltCitroJim wrote: 25 Jun 2026, 05:42 Yep, right on both counts... For that reason, only use a very high quality T55 bit. Far too many are made of stale French cheese and are about as much use![]()
