2015 Citroen C3 instrument cluster
william68
Unread post by william68 »
Hi, I've bought a 2015 C3 1.2 puretech with the 5 speed electronic autobox. Its a Japanese import and had the speedo dial changed to an MPH one, but the digital section is still in Kilometres. I'd like to have it all in miles, can the instruments be swapped without any ECU reprogramming, i.e. plug and play. Also, i have seen a 2015 set of instruments for a 1.2 petrol, would it matter if it came from a manual car? i.e. would the cruise control and gear indicator illuminate. From what I've seen with a light shone on the LED section, it looks as though all the same functions are present. Thanks in advance.
x 8121
Re: 2015 Citroen C3 instrument cluster
You may find this video helpful: :)
furriegurrie
x 40
Unread post by furriegurrie »
I think that dash is from an older model C3. Up to 2006 somewhere I believe.
PaulC5
x 685
Unread post by PaulC5 »
Have you looked in the handbook to see if the units can be changed. Often this can be done through a radio/screen menu. If you do not have the handbook they can be seen through this topic viewtopic.php?t=63208 and a quick look at a 2015 C3 one suggests around page 34 it says how to do it.
william68
Hi, the radio was replaced with an android unit with reverse camera, but on looking at 2nd hand clusters, the label says MPH. The original japanese dial only had kmph, not like the euro spec that has mph and kmph. I cant reset the tyre pressure warning either due to the radio being changed. I wonder if it can be done through the OBD socket.
PaulC5
x 685
If the TPMS warning is on the car will not pass the MOT so something that will need doing. If you find it can not be done via a diagnostic (and each time the tyres are pumped up) then you might need to swap the radio to an original one, if that is the cause.
If you bought the car from a dealer and it still has a warranty I would take it back to them to fix, especially if the TPMS was on at the sale as it was not up to MOT standards.
