citroen c5 x7 sill cover
avin44
Unread post by avin44 »
Does anyone know the best way to remove a plastic sill cover
up, up and away
x 8126
Re: citroen c5 x7 sill cover
I have no idea on the C5 but usually inserting a plastic trim tool under the cover and sliding it along will reveal the actual fixing points which you can then deal with as necessary. :)
PaulC5
x 690
Unread post by PaulC5 »
This topic might help a bit viewtopic.php?t=82956
x 1489
Moved this into Citroen
Lenny
x 62
Unread post by Lenny »
It mainly held by plastic clips as I recall.
I'd recommend getting some of the round, white plastic, trim clips beforehand as you're guaranteed to need some.
https://vehicleclips.co.uk/collections/ ... 1y8-9341pf
I reckon these are the ones.
