Peugeot Boxer No Start
MarcusWard
Unread post by MarcusWard »
I have just rebuilt the engine on my 2019 2.0 Blue Boxer.
When I started the rebuild the engine did run but bottom end was shot.
Sice fitting the engine it wont start, it fires and will run for about 5 seconds then stalls, interstingly whilst it is running the throttle pedal has no effect on the revs.
I am using a Launch 129X diagnostic machine and can see that cam/crank sync is ok, fuel rail pressure is good and the only fault codes relate to Nox sensor and DPF issues which were there before the rebuild.
I am running out of ideas because of the lack of fault codes!
Any advice would be very much appreciated!
x 8148
Re: Peugeot Boxer No Start
You may need to recalibrate the throttle, have a look at: https://erwinsalarda.com/how-to-perform ... -vehicles/ :)
MarcusWard
Thanks for the reply!
I’ll try that today
