Citroen c5 2.2 hdi 2013 parking brake
LinnMc
Unread post by LinnMc »
Hey everyone
I am all new here and to Citroen so please understand my constant state of confusion 😕
Want to start by saying I clearly did not do my homework before I started playing with the car, so this is what happened;
My caliper was stuck and rear brakes were bad so I started the job to butter up the caliper and change brakes.
No, I did not disconnect the battery and I did not put anything in service mode.
I had no idea I had to.
So, after replacing everything, all seemed fine. Then the rear brake cable cracked and spewed out brake fluid all over. Ordered a new one, and a new caliper.
Then, my mind blanked out and I let go of the brake cable so it got pulled in a little.
Found someone with Diagbox that got the cable out and it is now attached again.
But, I got Permanent, Error code U1219
Service lamp on, parking brake faulty and antirolll bar faulty.
Using Diagbox to fix the parking brake, it says calibrating then stops. Doing it manually and we can hear the motor try to pull the cables but then stops.
Our citroen dealer nearby doesn't touch it and don't wanna check what can be wrong, all they want to do is to replace the whole thing
Soo I have a couple of questions; the regular brake petal seems very soft. I have been bleeding the brakes but is it another that needs to be bleed? The ABS one through Diagbox?
Can air in the system cause the EPB to not be able to work properly?
An old mechanic told me I could try to grease up the wires, that there is a box on top of the rear axle that I can adjust and use a torx and grease them up. But Citroen says it's on the front axle because the parking brake is on the front wheels on my car?
Also, the only black box I find is in the middle under the car and contains the EPB engine.
Is there another one?
I am sorry for the long post, but I'm genuinely trying to learn and understand
/Linn
PaulC5
x 675
Re: Citroen c5 2.2 hdi 2013 parking brake
Unread post by PaulC5 »
I cannot help apart from point out it is the C5 models up to 2008 that have the hand brake on the front wheels. The ones from 2008 like yours have it on the rear wheels as you already know.
vallium
x 15
Unread post by vallium »
Left or right side?
If left undo the cap around cable and check nothing is broken. There is some plastic cup like thing and a heavy spring inside it that should not be seen. Something to do with cable tension measurement.
I've screwed up similarly right after car purchase, over tensioning cracked the cup. After glueing it up it worked for a while but was applying handbrake so hard that it cracked the pads. Final solution was used electronic handbrake from b-parts for 280€. Expensive moment of stupidity.
