Bom dia.
Gostaria de saber se alguém me pode ajudar a atualizar o radio e o GPS da minha peugeot 508.
O rádio é um rt6 e não consigo encontrar varia moradas no GPS, pois já deve estar desatualizado porque a carrinha é de 2013 e nunca deve ter sido atualizada.
Agradeço a quem puder dar uma ajuda
Atualização rádio e GPS rt6 peugeot 508 (Peugeot 508 RT6 radio and GPS update)
PedroF508
Onlinemyglaren
- x 5679
Re: Atualização rádio e GPS rt6 peugeot 508
Please post in English. Use a translator if necessary, as here, using DeepL
"Good morning.
I was wondering if anyone could help me update the radio and sat-nav in my Peugeot 508.
The radio is an RT6 and I can’t find many addresses on the sat-nav; it must be out of date because the car is from 2013 and has probably never been updated.
I’d be grateful to anyone who can help".
"Good morning.
- x 1953
Re: Atualização rádio e GPS rt6 peugeot 508 (Peugeot 508 RT6 radio and GPS update)
@PedroF508
Check your PM.
Check your PM.
PedroF508
Good morning.
I would like to know if anyone can help me update the radio and GPS in my Peugeot 508.
The radio is an RT6 and I can't find several addresses on the GPS, as it must be outdated since the van is from 2013 and has probably never been updated.
Thank you to anyone who can help.
PedroF508
Good afternoon again. I installed version 2.86 on my RT6 radio, but the maps have completely disappeared. I've already tried installing maps via USB drive, but the message "damaged or incomplete update support" appears on the screen. Could someone please help me? Thank you.
- x 1953
Try downloading the maps again.
PedroF508
Thank you, Paulo R.
Could you send the link to copy the maps back to a USB drive so I can see if I can get the maps again?
- x 1953
I have already sent you a PM. It hasn't changed.PedroF508 wrote: 19 Apr 2026, 22:13 Could you send the link to copy the maps back to a USB drive so I can see if I can get the maps again?
PedroF508
Thanks again, Paulo R.
Tomorrow I'll plug the USB drive with the file you sent back in and then I'll let you know how it went.
PedroF508
Good afternoon Paulo R.
I downloaded the maps again on my RT6, but it seems it didn't work yesterday because I hadn't generated the Java codes.
Today I did everything correctly as the tutorial explains, generated the Java codes, then just inserted the USB drive into the car and it immediately asked which maps I wanted to download.
I downloaded the maps of Portugal and Spain, which took about 20 minutes, and then I could just start driving.
Thank you for your help, without which I would still be looking for solutions
- x 1953
Thank you for reporting back on your success.
