Wiring /parts diagram C5 facelift model aircon / climat
sjc204
Unread post by sjc204 »
Citroen C5 Exclusive 2.0 HDI Estate 2006 with the automatic air con / climate control VIN VF7**************[VIN obfuscated, can be read by forum staff]
Trying to deal with non-operating heater blower.
Has anyone got a wiring diagram for this model? I just need the section about aircon / climate / heater. Or, the heater parts diagram might help.
The Mk1 C5 and C5X7 diagrams I have seen both look wrong for my car, as is the diagram in the Haynes manual.
Many thanks!
previous Citroens: 2CV6, Xantia TDi, Xantia TDi Estate, C5 HDI Estate
x 8122
Re: Wiring /parts diagram C5 facelift model aircon / climat
Which gearbox have you got? Presumably it is RHD as you haven't filled in the location field in your profile? Also the RPO number from the door sticker with the tyre pressures on should ensure I find the right diagram. :)
NB: DW10 BTED4 (E5) Engine
RPO: 10783
sjc204
Sorry, I have added those details to my profile. The car is right hand drive with 6-speed manual gearbox.
Door sticker:
10783CJ
10038
KKQD**
Thank you
x 8122
OK, this is the diagram for the heating:
C52 Heating.pdf
Copied from Sedre backup
(2.66 MiB) Downloaded 44 times
There are two possible diagrams for the aircon depending on whether it is Mono Zone or BI Zone so here are both options:
C52 Aircon monozone.pdf
(3.07 MiB) Downloaded 50 times
C5 Aircon BI zone.pdf
(3.23 MiB) Downloaded 57 times
Good luck! :)
sjc204
Thanks! I shall be needing some luck to decode those diagrams! They come out pretty low-res on my system. Many thanks for providing them, very helpful.
x 8122
I forgot to add a link to our Diagram Decoding guide: viewtopic.php?p=782862#p782862 :)
The diagrams are clear in Adobe on my laptop!! :)
sjc204
Thank you!
