Hello all. I am new here and seeking clarification on a job i am going to be doing next week.
Going to be doing timing belt on a 2020 Peugeot Expert III 2.0 BlueHDI DW10.
My question is, is the high pressure fuel pump timed?
I have watched a couple videos and there is no signs or mention of the HP pump being pinned and locked before removing the belt. Yet when I look online, it says that it should locked to keep it synced.
After finding TDC should I be able to pin the larger timing hole on the cam gear as well as the smaller hole which is for the HP pump?
Any advice would be greatly appreciated.
2020 Peugeot Expert III 2.0 BlueHDI DW10 HP Pump timing
Ulook92
tricoloured
- x 14
Re: 2020 Peugeot Expert III 2.0 BlueHDI DW10 HP Pump timing
Hi
I had this with my Expert DW10FC, this may help if I have attached it correctly.
And this was interesting: https://www.repxpert.us/en-us/training- ... ssure-pump
Bobby
Bobby
- Attachments
Fuel Pump Timing.pdf- (919.22 KiB) Downloaded 369 times
