SH fuse/Shunt fuse
Kloppster333
SH fuse/Shunt fuse
Unread post by Kloppster333 »
Evening folks. A very basic question here as I am obviously using the wrong spare fuse name when trying to order a fuse. Simply put, I was doing a test of certain fuses in the dashboard fusebox. One which I accidentally took out and proceeded to completely lose was the SH fuse, or otherwise named Shunt fuse, so obviously my car turns over now but won't start. Has someone got a link you could kindly post please of somewhere UK I can order online like Halfords or Amazon. When I put shunt in the search nothing comes up. I know what the fuse is for (now), and been advised it's around £10 to buy. Someone also suggested to put a 40amp blade fuse in instead, but that doesn't fit at all. Please and thank you in advance.
Kees
x 148
Re: SH fuse/Shunt fuse
Unread post by Kees »
The shunt is NOT a fuse!! It's a special resistor.
So i think you have to go to the dealer and btw take al the information about the car with you, because there are several different Citroën C5.
In your post you don't described which type you speaking about.
x 1459
Unread post by xantia_v6 »
The part number is 650481
You should be able to order one from a dealer.
The official PSA heritage site sells them: https://www.boutique-laventure-associat ... shunt.html
Or find any PSA car from the era in a scrapyard.
x 1938
Unread post by Paul-R »
Kees wrote: 23 Mar 2026, 19:40 The shunt is NOT a fuse!! It's a special resistor.
Are we sure there's a resistance inside a shunt? I don't think there is so why not take an ordinary fuse of any value and solder a thickish wire across the two terminals? Or, even easier, just plug a high value (30A?) fuse in. Put a dob of paint on to identify that it's not an ordinary fuse.
Actually I don't think there's any great current flowing through the shunt and so any value fuse could be used.
x 1459
The shunt is not a resistor with a specific resistance, it is just (as close as they can get) a short circuit. The pins are a different spacing so you can't mistakenly swap it with a normal fuse.
x 1938
xantia_v6 wrote: 23 Mar 2026, 20:50 The shunt ... pins are a different spacing so you can't mistakenly swap it with a normal fuse.
Now that I didn't realise. I take it all back.
x 1052
Unread post by wheeler »
Correct its a dead short, no resistance inside it.
The legs are spaced slightly wider apart so you cant put a regular fuse in there.
as a temporary repair till you get the correct shunt loop a thick pace of wire & crimp 2 male spade terminals on to it & bridge with that
Kloppster333
Thanks everyone. I have one on order now. Really appreciate the help.
