Hi, our 2017 2.0hdi 160 GP has thrown up the light for the additive pump. I plan to get it sorted but also wondered if, other than being annoying, there'd be any consequences to just continuously driving it and adding eolys manually at each fill up...
Would it progress to STOP from SERVICE?
Thanks in advance!
Paul
P1434.96 error code. Will it ever progress to a "STOP" light?
Paul73
- x 8126
Re: P1434.96 error code. Will it ever progress to a "STOP" light?
You may find a read through this thread will help: viewtopic.php?t=73128
PaulC5
- x 691
If the engine management light is on it might not pass the next MOT so it will need fixing by then even if adding fluid manually before each diesel fill helps stop the dpf getting blocked.
Paul73
Hi thanks, I had seen that but it didn't answer my question hence the askmickthemaverick wrote: 22 Mar 2026, 19:20 You may find a read through this thread will help: viewtopic.php?t=73128
Paul73
Thanks, yes i suspect that might be an issue. thankfully mot is a long way off at the mo!PaulC5 wrote: 22 Mar 2026, 21:37 If the engine management light is on it might not pass the next MOT so it will need fixing by then even if adding fluid manually before each diesel fill helps stop the dpf getting blocked.
