Hi Folks
Nemo when start seems ok leave it a few seconds will make a couple of knocks/kinda change pitch
Then go to normal and then sound like a bag of spanners for a few secs
Spoke to garage and they are unsure as it seems like if your playing the piano
all notes are the same and then drops 1
This nemo at 50k is costing me a lot in repairs this year
cannot believe its just so poor
Nemo knocking on startup
- x 8126
Re: Nemo knocking on startup
First thing to check is your oil level and quality. It sounds like it is taking time to lubricate the top end which may be due to lack of oil, over thick oil or possibly weak oil pump.
ohspecial1
Might be worth doing another oil change i done it in january dipstick isnt showing low but maybe it is
- x 8126
Did you use a decent make of filter and the correct spec oil? Have a look at the video I posted earlier on the DIY Motoring thread in the Off Topic Chat Lounge.for some info about oil specs.
viewtopic.php?p=864128#p864128
ohspecial1
Hi i used Castrol 5w30 c2 oil
And bosch oil filter
Seems only like on idle to drop a like car starts and then drops note then goes back again
But you don't hear nothing when its driving
ohspecial1
Could it be a bearing or something around by the belt with the alternator
Sounds odd but seems like a clutch or relay clicking
