hi
all got a 2003 2.0 c5 mk1 citroen with 4l auto box and was told by the org owner it hasnt got a turbo but not sure anyone tell me or give me a idea were to look
ty
Re: mk1 c5
PaulC5
- x 699
Re: Re: mk1 c5
If a diesel it will have a turbo, if petrol it will not have a turbo according to the Haynes workshop manual.
Onlinenotinserviceuk
- x 5
Re: Re: mk1 c5
were is it not on top engine 44
PaulC5
- x 699
Re: Re: mk1 c5
I do not understand this comment, please explain a bit better. Also is your car a petrol or diesel ?
Sloppysod
- x 398
Re: Re: mk1 c5
As per duckduck.ai
The turbo on the Citroën C5 Mk1 (2000-2008) is typically located between the bulkhead and the rear of the engine, accessible from underneath the vehicle. It's advisable to check for any leaks in the boost pipes if you're experiencing issues.
The Citroën C5 MK1, produced from 2000 to 2008, features a turbocharged engine option. The turbocharger is typically located at the rear of the engine, between the bulkhead and the engine block.
Accessing the Turbo
Location: The turbo is positioned towards the back of the engine, making it somewhat difficult to access.
Inspection: To inspect the turbo, you may need to access it from underneath the vehicle, as it is situated under the scuttle panel.
Common Issues
Symptoms of Problems: If you hear a "whoosh" sound during acceleration, it may indicate a boost leak rather than a turbo failure.
Check Boost Pipes: Inspect the boost pipes for any splits or leaks, as these can cause performance issues.
This information should help you locate and understand the turbocharger in your Citroën C5 MK1.
Accessing the Turbo
Common Issues
Stu
- x 1943
Re: Re: mk1 c5
Only if it's a diesel engine. We still don't know whether we're dealing with petrol or diesel.Sloppysod wrote: 20 Mar 2026, 16:12This information should help you locate and understand the turbocharger in your Citroën C5 MK1.
Maybe a simple question will get an answer. Does the engine have spark plugs or glow plugs?
- x 1056
Re: Re: mk1 c5
On the 2.0 HDi the turbo is down the back of the engine if looking facing the front of the car.
- x 5
Re: Re: mk1 c5
thanks all for all the help
