Hi
I just replaced injector no 4 in my 2018 Citroen C4 Grand Picasso 2.0 HDI DW10F. I coded the new injector to ECU but i can't turn off EML it keeps showing fault code P3035 driving conditions not suitable for resetting the diesel injectors. And the engine is idling at 1250rpm. I would be very grateful if anyone had this problem and has any ideas of how to fix it!
Thanks.
Injector coding
- x 1942
Re: Injector coding
When you coded the the new injector in you count from the gearbox end of the engine as that is the way that PSA number their engines?
- x 8119
Re: Injector coding
Just to be sure you are counting the cylinders in the correct PSA way, No 1 at the flywheel end?
Paul812
Re: Injector coding
Yeah, the one i replaced is closest to the timing belt!
- x 1942
Re: Injector coding
What are you using to code in the new injector?
- x 8119
Re: Injector coding
You may find this helpful, there is a language option at the top
https://poszukaj.elektroda.pl/qa,blad-p ... iesel.html
Paul812
Re: Injector coding
Launch creader elite V2.0. It has changed the code for me but it's still showing the P3035 fault
