peugeot 207 1.6hdi 2007
after some other work removing the wiper mechanism but not removing the cables, installed it back and the next day the wipers and front headlights were coming on by themselves.
today I took off the cowling and wipers to check the wiring, and while the fault was present I unplugged the wiper motor, of course they stopped but headlights still on, so that fault was coming from the wiper motor circuit.
have stripped the wiring back to where it goes through a grommet into engine bay and its all good, dry and not chaffed.
I have got out the engine fuse board [its a 9661708280 board], disconnected battery and unplugged all the connectors, no greeny bits [corrosion] on any of the pins or in the plugs, the board underneath has Maxi fuses in it, I removed each and cleaned contacts, there was a drip or two out of there but I blew it out with airline but there was no water in bottom of fuse box.
207 wipers and front lights on engine off
nikeastwood
- x 24
no egr, no dpf, no problems.
- x 8119
Re: 207 wipers and front lights on engine off
I'm not sure I realise what you are asking?
PaulC5
- x 683
Check the battery voltage in case it is low. A fully charged battery before the first engine start of the day should be about 12.7 volts, if below about 12.3 volts charge it up. On our C5 when the battery has been flat it has put the headlights on and the wipers have moved when trying to start it.
nikeastwood
- x 24
these cars are mental with electrics. put it all back together, still the same. then a sidelight warning popped up for front side, I changed that and now its totally happy.
was almost about to buy another car!
