Xantia 1997 2.0i Fuel gauge and warning light
LochNessie
Unread post by LochNessie »
Needle seems to be stuck at 1/2 tank and warning(yellow) light constantly Lighted Up, even when tank is Full.
faulty "sender" the fuel float inside fuel tank is defective?..of yes, can the sender be serviced or I need to replace it?
Thanks in advance for advice
x 8149
Re: Xantia 1997 2.0i Fuel gauge and warning light
You may be able to fix it but it is a have a look and go from there job!! :)
x 2004
Unread post by Stickyfinger »
Tank sender or broken/dry solder on the instrument cluster...
x 1473
Unread post by xantia_v6 »
Try unplugging the connector on the fuel sender unit (under the back seat). With it unplugged, the warning light should go out and gauge read empty. If not, you have a problem in the wiring or the dashboard.
