Needle seems to be stuck at 1/2 tank and warning(yellow) light constantly Lighted Up, even when tank is Full.
faulty "sender" the fuel float inside fuel tank is defective?..of yes, can the sender be serviced or I need to replace it?
Thanks in advance for advice
Xantia 1997 2.0i Fuel gauge and warning light
- x 8151
Re: Xantia 1997 2.0i Fuel gauge and warning light
You may be able to fix it but it is a have a look and go from there job!!
- x 2004
Tank sender or broken/dry solder on the instrument cluster...
- x 1473
Try unplugging the connector on the fuel sender unit (under the back seat). With it unplugged, the warning light should go out and gauge read empty. If not, you have a problem in the wiring or the dashboard.
