Grand picasso 2015 heater / fuse help
Ck111
Unread post by Ck111 »
Hi. I have checked on here but cant seem to find a definite answer. The blower fan is not working at all and was hoping for a simple blown fuse fix but cant locate which fuse or fuses i should be checking.
Background of my problem is that water has got in through the drivers side wheel arch drain as it was blocked. I noticed this on Thursday morning and cleared it on Friday evening. I took apart the lower dash and water has def entered at least one connector which i tried to dry out today as best i could. I then blew air in around the area.
Can anyone help with fuse locations so i can rule that out
x 8149
Re: Grand picasso 2015 heater / fuse help
Unfortunately I only have access to data on cars up to 2012 so I cannot help but hopefully someone with the right access will soon. I take it you have checked your handbook? :)
Ck111
Unfortunately i cant find the handbook, but thanks
x 8149
PaulC5
x 701
Unread post by PaulC5 »
Handbooks also through this topic viewtopic.php?t=63208
