blue smoke periodically
gsc1ugs
x 3
Unread post by gsc1ugs »
Got blue smoke at tick over, could that be turbo or injectors? driving i cant see any! Thanks in advance
CITROEN NEMO 1248cc diesel van
Regards
x 8147
Re: blue smoke periodically
Blue smoke is a sign of burning oil so it may be the turbo or possibly piston rings failure or maybe a crack in the head. There are too many possibilities really to speculate. You need to get a diagnostic test done with a high end system like diagbox and see what codes it throws up. :)
gsc1ugs
x 3
What about injector seals?
x 8147
Indeed, another possibility, that usually will be visible with oil pooling in the injecture ports :)
