Got blue smoke at tick over, could that be turbo or injectors? driving i cant see any! Thanks in advance
CITROEN NEMO 1248cc diesel van
Regards
blue smoke periodically
- x 8151
Re: blue smoke periodically
Blue smoke is a sign of burning oil so it may be the turbo or possibly piston rings failure or maybe a crack in the head. There are too many possibilities really to speculate. You need to get a diagnostic test done with a high end system like diagbox and see what codes it throws up.
gsc1ugs
- x 3
What about injector seals?
- x 8151
Indeed, another possibility, that usually will be visible with oil pooling in the injecture ports
