Pulling to left , and juddering
Stevie b
Unread post by Stevie b »
Hi my van is pulling to left on acceleration
And also juddering , the steering wheel is jumping out my hand , it can drive for 40 miles perfect then starts pulling to left , any ideas please
x 1940
Re: Pulling to left , and juddering
Unread post by Paul-R »
On my daughter's Vivaro camper van there was a pronounced pull to the left that was cured by a new left bottom ball joint on the front suspension. It was quite badly worn but had not long passed an MOT so a recent test is no guarantee it's OK.
Stevie b
Its intermittent, you would think if it was ball joint it would do it all the time , thanks for reply
x 1940
Hers was there all the time so not the same as yours.
PaulC5
x 697
Unread post by PaulC5 »
What van is it, how many miles, year, which engine ?
Could be suspension, cv joint, steering rack, brakes, tyres - a garage might be best to check all these on a ramp since they are not always easy to check.
Oldpug
x 94
Unread post by Oldpug »
Stevie, you say the steering wheel jumps out of your hand. That to me points to a drive shaft, the CV joint is cracking up. Get it checked out by a small indy.
