Heater control valve - 307
NickCUK
x 3
Unread post by NickCUK »
Anyone know where the heater control valve is on a 307 with manual heater controls?
My temperature knob feels awkward to turn and I am not sure the system is delivering the correct amount of heat when on maximum. Recently had the clutch changed if that is likely to have any bearing on the matter.
x 8125
Re: Heater control valve - 307
What year is the car? :)
PaulC5
x 690
Unread post by PaulC5 »
If it is a cable from the back of the knob to the heater warm air flap then we had a 2010 C3 like this and the warm air flap was not being moved. A new cable did not help much and eventually we had the complete heater unit replaced as it turned out the flap was seizing up causing the cable to bend.
