2015 Berlingo 1.6 hdi no start
Johnjo8465
Unread post by Johnjo8465 »
Hi guys my Berlingo died on the way home the other night science then I have changed the fuel filter and fuel rail pressure switch I'm only getting between 5 and 8 bar of rail pressure when cranking I'm an the stage where I'm ready to change the hpfp but I have a f5ff error code for the bsi which it niggling at me asso when all codes have been cleared the EML won't go out so that's what's drawing me to this code and no start I also did a leak off test to see if it was the injectors that were at fault but had no fuel going to them has anyone ever experienced this before ? Thanks in advance
x 8144
Re: 2015 Berlingo 1.6 hdi no start
A read through this thread may give you some ideas: :)
viewtopic.php?p=722395#p722395
x 1496
Have you checked the timing belt? Pretty much the only reason these engines stop is when the belt goes....
Johnjo8465
Hi Richard yes had the cover off and checked the belt the van will fire when a shot of easy start is introduced but just cranks without it I have a spare pump in the garage just trying to eliminate everything else before I take the plunge and change it the f5ff code and illuminated EML that's got me thinking it's not the pump I even tried the van with a tow but the rail pressure would not go above 8 bar I don't have the Citroen diagnostics software that mabee dig a bit deeper
PaulC5
x 698
Unread post by PaulC5 »
Possibly a stupid question but have you run out of fuel ?
Johnjo8465
Hi Paul it's sitting with three quarters of a tank in it
moizeau
x 423
Unread post by moizeau »
Crank sensor? Have you got cam/crank sync on diag?
Pete
Johnjo8465
Hi yes there both in sync
x 1496
Good news on the belt. The BSI 5f55 code is almost always there, but doesn't mean anything. Changing the pump is not easy, ideally you would check the fuel pressure first to rule out the pressure sensor (which is only marginally easier to change!).
Johnjo8465
I changed the fuel rail pressure sensor on it but still got the same reading only thing I've not done is the fuel pressure regulator on the pump 🤔
