308 t9 sw front spring
james47563589653
Im changing the springs on the front of my 308 and the replacements have one end that is flat and the other end is angled, do the springs have a specific orientation
- x 8110
Re: 308 t9 sw front spring
Yes they do, the angled end is usually to fit into the strut top but when you look at the top and bottom it should be obvious which one is flat!!
james47563589653
I have fitted it both ways both seem wrong and when i piece together the old one it seems flat at both ends
- x 8110
Unfortunately my diagram resource only covers pre 2013 cars so I cannot check the parts diagram for you but hopefully one of the members with access to the later cars will help out.
PaulC5
- x 681
If these are copy parts and not from a Peugeot dealer they might not be the correct ones. Beware that copy parts may not behave as the originals and the car height can be wrong.
