Oil pump chain slack on a 1.2 Puretech 130 turbo?
Newport67
Unread post by Newport67 »
Hello,
I'm in the middle of doing the timing belt on my 2018 5008 and while taking the crank sprocket off, the oil pump sprocket tried to follow it and when I pushed it back on the crankshaft I noticed that the chain is quite loose. I almost thought it came of the pump sprocket, but that's fine.
I can't find specs anywhere. The chain looks fine. Is this normal for this chain on the Puretech?
Thanks in advance,
Thomas
x 1940
Re: Oil pump chain slack on a 1.2 Puretech 130 turbo?
Unread post by Paul-R »
As far as I know the sprocket is an integral part of the camshaft. This is why the cams are changed when making the 8mm chain conversion. If the sprocket is loose that's a very bad sign and needs changing. I'd look at the other camshaft sprocket very close. In fact I'd even think going down the complete 8mm conversion if you're that far into the engine.
Newport67
Thanks Paul. However, I was referring to the oil pump chain that runs off the crankshaft behind the crank sprocket that the timing belt runs on.
Anyway, as an update - the chain did come off the oil pump sprocket. I checked using a mirror. I did manage to 'swing' it back onto the gear in the sump (so don't have to take that off) but that chain is still darned loose. The chain links don't seem to have any play in them so I guess that's how they are.
PaulC5
x 697
Unread post by PaulC5 »
Paul-R wrote: 04 Dec 2025, 17:42 As far as I know the sprocket is an integral part of the camshaft. This is why the cams are changed when making the 8mm chain conversion. If the sprocket is loose that's a very bad sign and needs changing. I'd look at the other camshaft sprocket very close. In fact I'd even think going down the complete 8mm conversion if you're that far into the engine.
Is this for the 1.5 hdi engine and not the 1.2 Puretech ?
x 1940
Yes it is. My mistake. I was misled by the use of the word chain.
Mihael_M
x 37
Unread post by Mihael_M »
It's not a Puretech 1.2 with 3 cylinders and it's not a 1.5 HDI either. This engine has 4 cylinders. The oil pump has its own chain and it is certainly not good for it to be loose. Although I do not have the technical instructions that you should find. Since the chain does not have a spanner there must be a way to tighten it.
Newport67
Hello all,
Quick update for the motor I happen to have ;)
Unfortunately, the chain won't slip past the oil pump gear and engine wall. Approx 1.5 mm too narrow.
So... I shall travel forth with the loosey goosey chain I've got.
I've attached a pic after dropping the oil pan.
Cheers
