Hello dear all,
I found the EP3 guide, is it also the same guide for EP6?
Do I need to bleed air outside with cap open or not? not sure, also some friend of mine not sure, he's not a mechanic but it's his hobby
I also found the guide of 207, which states opened cap, in the EP3 guide, closed cap
Thanks,
Golden
Regarding coolant change in Peugeot 208 VTi Prince 1.6 EP6
GoldenB191
- Attachments
207 EP3x Drain-Refill.pdf- (221.74 KiB) Downloaded 77 times
- x 8093
Re: Regarding coolant change in Peugeot 208 VTi Prince 1.6 EP6
What system are you trying to bleed?
GoldenB191
Coolant system.
Bleeding air.
You let the coolant go from the radiator hose down there, and then air gets in.
Bleeding air.
