Citroen C3 occasional knocking while reversing
pgfanning
Unread post by pgfanning »
My 2019 Citroen C3 is knocking occasionally especially when reversing. Very occasionally when turning. Any help / advice much appreciated. Thanks.
x 8153
Re: Citroen C3 occasional knocking while reversing
Possibly a worn track rod end or inner steering joint, maybe a suspension ball joint or a fair number of other possibilities. It really needs jacking up each wheel and looking for movement in the joints. :)
pgfanning
Thanks Mick. Should it go to a garage straight away?
x 8153
It's always better to be safe than sorry. Have it checked out by someone who knows what they are doing. :)
pgfanning
Great. Thanks.
PaulC5
x 705
Unread post by PaulC5 »
Check the exhaust hanging brackets, these rust off the exhaust and can give a knocking noise. Citroen will want to sell a new exhaust or weld it back but a cheaper option is to fit clamp on repair brackets, these are available from Autodoc. I have replaced them on a C3 and a Cactus and are easy to fit. Before looking under the car, you can hold the tail pipe and push the exhaust about to see if you get any noise.
pgfanning
Thanks.
