Citroen C3 occasional knocking while reversing
pgfanning
My 2019 Citroen C3 is knocking occasionally especially when reversing. Very occasionally when turning. Any help / advice much appreciated. Thanks.
- x 8083
Re: Citroen C3 occasional knocking while reversing
Possibly a worn track rod end or inner steering joint, maybe a suspension ball joint or a fair number of other possibilities. It really needs jacking up each wheel and looking for movement in the joints.
pgfanning
Thanks Mick. Should it go to a garage straight away?
- x 8083
It's always better to be safe than sorry. Have it checked out by someone who knows what they are doing.
pgfanning
Great. Thanks.
PaulC5
- x 670
Check the exhaust hanging brackets, these rust off the exhaust and can give a knocking noise. Citroen will want to sell a new exhaust or weld it back but a cheaper option is to fit clamp on repair brackets, these are available from Autodoc. I have replaced them on a C3 and a Cactus and are easy to fit. Before looking under the car, you can hold the tail pipe and push the exhaust about to see if you get any noise.
pgfanning
