HELP!! Wiring diagram needed 2015 Peugeot 5008 2.0 hdi intermittent p2685 supply of 5v sensors..CAR CUTS OUT
Cruiser786
Unread post by Cruiser786 »
Hi all i have a 2015 Peugeot 5008 2.0 hdi auto.
This car will just randomly throw up various fault codes & cut out ,will not start again but then will just randomly start a few days later sometimes the same day.
The fault code i get is p2685 supply of sensors 5v no3(camshaft ,engine speed & rail pressure)
As long as this code does not clear car will not start.
I have had a replacement ecu in there which made no difference.
I believe 1 sensor is short circuiting causing this fault code ,I have also disconnected all the sensors I can get access to from the top cam,crank fuel rail ,egr ,air mass ,throttle body e.t.c but fault remains.
Anyone have a wiring diagram they can send me ,i want to track the 5v wiring from the ecu.
Thanks in advance
Car reg kv15 nya
x 8085
Re: HELP!! Wiring diagram needed 2015 Peugeot 5008 2.0 hdi intermittent p2685 supply of 5v sensors..CAR CUTS OUT
I'm afraid I don't have diagrams for newer than 2013 cars so I cannot help but hopefully one of the members with their own access to the Stellantis database will see your post and help you out. Good luck :)
