Hi all i have a 2015 Peugeot 5008 2.0 hdi auto.
This car will just randomly throw up various fault codes & cut out ,will not start again but then will just randomly start a few days later sometimes the same day.
The fault code i get is p2685 supply of sensors 5v no3(camshaft ,engine speed & rail pressure)
As long as this code does not clear car will not start.
I have had a replacement ecu in there which made no difference.
I believe 1 sensor is short circuiting causing this fault code ,I have also disconnected all the sensors I can get access to from the top cam,crank fuel rail ,egr ,air mass ,throttle body e.t.c but fault remains.
Anyone have a wiring diagram they can send me ,i want to track the 5v wiring from the ecu.
Thanks in advance
Car reg kv15 nya
HELP!! Wiring diagram needed 2015 Peugeot 5008 2.0 hdi intermittent p2685 supply of 5v sensors..CAR CUTS OUT
Cruiser786
- x 8027
Re: HELP!! Wiring diagram needed 2015 Peugeot 5008 2.0 hdi intermittent p2685 supply of 5v sensors..CAR CUTS OUT
I'm afraid I don't have diagrams for newer than 2013 cars so I cannot help but hopefully one of the members with their own access to the Stellantis database will see your post and help you out. Good luck
