Can anyone help me with wiring diagrams for ABS,ECU and START/STOP relay so I can check CAN lines?
Citroen C3 2016 no crank no start.
Codes are related to start relay based on description
Codes: P0685, P13C1, P0615, P16BA
Is it possible that if the ABS CAN line is faulty, the ECU has no connection with the Start/Stop relay module?
Citroen C3 2016 ABS wiring diagram
limartovi
- x 8057
Re: Citroen C3 2016 ABS wiring diagram
I don't have access to diagrams for 2016 cars I'm afraid but you should post your engine and gearbox types so that those that do will find the right diagram.
limartovi
Engine is 1.6 blueHDI
Manual
ABS controller: MK 100 ESC
Manual
