Citroen C3 2016 ABS wiring diagram
limartovi
Unread post by limartovi »
Can anyone help me with wiring diagrams for ABS,ECU and START/STOP relay so I can check CAN lines?
Citroen C3 2016 no crank no start.
Codes are related to start relay based on description
Codes: P0685, P13C1, P0615, P16BA
Is it possible that if the ABS CAN line is faulty, the ECU has no connection with the Start/Stop relay module?
x 8144
Re: Citroen C3 2016 ABS wiring diagram
I don't have access to diagrams for 2016 cars I'm afraid but you should post your engine and gearbox types so that those that do will find the right diagram. :)
limartovi
Engine is 1.6 blueHDI
Manual
ABS controller: MK 100 ESC
